Contractor Recommendation in Pittsburgh, PA
Andrew_8
Member Posts: 15
Can someone recommend a good contractor that works in the city Pittsburgh that will take the time to do a heat loss calculation before giving me an estimate for the job?
I've gotten two quotes, one guy just sized the same as my current boiler, the other upsized. My current 32 year old boiler only runs constantly on a 0 degree day, and the house is still comfortable even then.
I am looking to switch from a conventional boiler, driving mostly cast iron rads and a radiant floor loop, to a condensing modulating boiler, possibly with an indirect water heater. I'm having a lot of trouble locating a contractor who I feel I can trust.
I am ready to have this work done this summer, if I can find the right contractor.
Thanks!
Andrew
Thanks!
Andrew
At least it sounds like your present boiler is well sized, so as to run nonstop at your design temperature!
Just run everything ,which is recommended, by here, for many expert comments.--NBC0 -
I meant to ask if you had tried the find a contractor button here.--NBC0
I did try that link. No contractors listed within 100 miles of my location.0
I'm surprised that nobody is in your area. Some people from the Cleveland area frequent this site. Can they legally work in Pittsburgh? If you are absolutely desperate, you could hire a pro from out-of-state to make a consultation visit, draw up a heat loss and the total scope of work which you can then hand off to the most reliable company that will be guaranteed to follow those plans.
I haven't been to Pittsburgh yet!0 -
Gets no better than Harvey.Retired and loving it.0
Do you know when you would be in Somerset? It's maybe an hour and half from Pittsburgh.0
The building is still in the planning stages. I'll probably be out there in October I'm guessing.
May be a little late in the year for you?0 -
Yeah, probably a bit later than I'd like, if I can help it. The Phillies play the Pirates here in Pittsburgh in June if you are a baseball fan.0
Sounds like fun! Send me a PM and we'll see what we can arrange.0
You are correct Mark. I forgot he was in Pittsburgh. Here is his website http://www.fireiceheat.com/
Andrew, he can get you fixed up. Extraordinarily smart man Ray is. You should give him a call.0 -
I did not know that either. My wife grew up in Dormont.0
Sorry for disappearing. My day job got real busy. I will give Fire-n-Ice a call, but they appear to be only commercial.
I got a picture from the first contractor. At first glance, I don't see an air separator and the expansion tank is fed from the bottom, so I don't see how the air is removed from the tank.0 -
Can you post the picture so we may critique it?0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 984 Plumbing
- 389 Solar
