Reactivating an old radiant heating system
aschwa
Member Posts: 24
Hi all-
I moved into a home in the San Francisco Bay Area last year. It was built in 1964 and renovated in the late 90s.
The home is a two-story home.
I recently discovered that the previous owners who did the remodel in the late 90s disconnected the original hydronic radiant floor heating system because they were concerned about leaks (they apparently had a leak and decided that they wanted to disconnect the whole system instead of dealing with it). They put in a forced air system in its place.
Underneath the carpet on the second floor, I've discovered the pipes for one of the two floors coming up where the previous remodel cut them off. I suspect that it won't be too hard to find the pipes for the first floor.
The pipes themselves are copper (not galvanized steel fortunately). I think that they are embedded in concrete (I don't think gypcrete was used in the 60s).
Here's my question: is it worth trying to reactivate this 50-year-old radiant floor heating system that was drained 16 years ago? Or is it likely to be more trouble than it's worth? We're about to start a remodeling project of our own, so now would be a good time to do it. Will copper pipes degrade because they were dry for 15 years? Are copper pipes that were embedded in a concrete slab 50 years ago likely to have much life left in them? Is this a bad idea for any other reason?
I suspect that some of the pipes may have been cut during the previous remodel to open up a foyer area, but I suspect that that will only affect a small portion of the system and can presumably be identified by a leak detection.
Thanks!
Thanks!
Pressure test the pipes with air (no more than 15 PSI to start.) See how long that holds.0
Any competent plumber can handle it -- no need for fancy leak detection until you know at least what parts have leaks.
SharkBite fittings work well for this. You'll need one plug and one male adapter to test a loop, along with an air test gauge. If the pipes are 3/4" copper, you could start with one each of these:
http://www.supplyhouse.com/Cash-Acme-U518LF-3-4-EndStop-Lead-Free
http://www.supplyhouse.com/Cash-Acme-U134LF-3-4-x-3-4-Pipe-to-Male-Pipe-Thread-Connector-Lead-Free
http://www.supplyhouse.com/Cash-Acme-U712-3-4-Disconnect-Clip-4464000-p
http://www.supplyhouse.com/Winters-Instruments-PETG202-2-PET-Economy-Gas-Test-Pressure-Gauge-0-30-PSI
You'll also need a bit of Teflon tape or pipe dope and an air compressor (or a decent bicycle pump.)0 -
If the pipes can hold pressure, would you recommend that I reactivate the system despite its age?0
I don't know swei . They may hold pressure now but in a few years ? Lotsa lime in that there old cementitious detail . Ever see those copper pipes after 1/2 a century in concrete / cement ? It can be quite ugly .You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
My two cents..........I wouldn't do it. There was and is, no way to deal with it if it has begun to fail. It's like only replacing a rotted out muffler on your car. It will just leak elsewhere. I don't care for the previous owners choice of heating systems, but agree that it should have been abandoned.0
Levitt systems have a 50 year life expectancy. Not worth the investment to fix the old. The Bay area has a housing market that should accept a hydronic renovation without loss of property value.
Generally agreed, but most of us have come across at least one of those old systems that still held pressure. My take is that it's worth testing.
For the record, I would never connect one to an autofeeder. Something akin to ME's PIG (or just an oversized expansion tank) would be in order. This requires a competent hydronic pro -- check references well!0 -
Isn't Allen Forbes in SF?0
East Bay, I think - pretty sure he's on the road at the moment. Eichler country for sure.0
Is there a way to install a new radiant floor heating system without raising the floors? Would this involve demolishing a few inches of the existing concrete on the first and second floor? Or is this impossible, because it would damage the foundation?0
My house was built in 1950 and the downstairs is radiant slab at grade. Heat there is mostly 1/2 inch copper tubing. If I turn the makeup water off, it will hold pressure until I get tired of looking at the pressure gauge. Several days. So I suppose it is not leaking.
Maybe they used heavy wall copper tubing. Maybe the concrete mix contained less harmful stuff (fly ash?). Anyhow, it still works. The house across the street still works too. We have both replaced the boilers. Mine is now a gas fired mod-con. I think the guy across the street still uses oil.0 -
What I have found with tube in concrete is that it will last IF it is encased completely and remains dry.
If the tube touches moist fill below, or the slab has moisture, then corrosion is possible.
Tough to know that, so it becomes a roll of the dice, with metallic tube in, or partial in concrete slabs.Bob "hot rod" Rohr
Copper in concrete I would say professionally no. They obviously had a leak and decommissioned the system for a reason. I have seen what used to be tubing as just holes or channels in the cement. No copper visible. Once a leak starts Lyme gets introduced into the system. This could happen for months even years before the leak shows itself. Meanwhile the owner can't understand why they suddenly need so many parts changed near the boiler. Finally it's a leak and it's done.
Research other means of hydronic heat but do not put a penny into the system you discovered.LANGAN'S PLUMBING & HEATING LLC
Considerate People, Considerate Service, Consider It Done!
732-751-1560
email: langansph@yahoo.com
www.langansplumbing.com0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 990 Plumbing
- 389 Solar
