Is this EDR calculator as good any other?
Jack M
Member Posts: 239
I was using this one but thought I would ask what others are using:
columbiaheatingsupply.com/page_images/Sizing%20Cast%20Iron%20Radiator%20Heating%20Capacity%20Guide.pdf
That looks fine. I would pretty much ignore the BTU's for steam and stick with trying to match the sq ft of steam the boiler is rated for to the total system EDR.
Keep in mind the boiler rating hides the 33% pickup factor so you may want the boiler sq ft to be less (10 to 20% less) than the system EDR, it depends on the system layout and how well the basement piping is insulated. You don't want the system to short cycle but not having enough steam to heat the house on a very cold day is worse than short cycling.
3PSI gauge0 -
I actually have that one saved on my desktop and used it to compute the EDR of all my radiators prior to my boiler replacement last year.
I think it's as good as any...I have a hot water system and just wanted to compare the installed EDR to my calculated heat loss of each room in my house. Led to some interesting observations.Ford Master Technician, "Tinkerer of Terror"
Police & Fire Equipment Lead Mechanic, NW WI
Lover of Old Homes & Gravity Hot Water Systems0 -
I use the one in the Burnham Heating Helper.
http://usboiler.net/library/USBoilerReport/heatinghelper/index.html0 -
This is a nice resource. I had not come across it. Lots to read up on here.Jason said:I use the one in the Burnham Heating Helper.
The EDRs listed match what I was using, and that is comforting.
I like this chapter which I copied years ago from and ASHRAE guide. It makes a distinction between "large tube" and the slenderized "small tube" cast iron radiators. Often times the large tube version is referred to as small tube, leading to much confusion.
Other than this, Dan's EDR book is great as well as the original manufacturer handbooks. One type that is always off the charts is the various "flue" radiators. Particularly the American Radiator "Italian Flue" and the "Window Flue" radiators. Ratings are higher than similar sized radiators.Dave in Quad Cities, America
http://grandviewdavenport.com0
- 121 Chimneys & Flues
- 15.8K Strictly Steam
