EZ-Gas burner does not start after amber checkout light
Steve Garson_2
Member Posts: 712
in Gas Heating
My burner does not start after the amber checkout light illuminates. The motor does not start. Everything was fine until ten minutes ago when I flushed the boiler.
Any suggestions?
Steve
Any suggestions?
Steve
Steve from Denver, CO
Get Charles Garrity out there
Charles called me on the phone. I had just flooded the boiler to try to find a leak. There was none. He knew exactly why the burner wouldn't work: the Vaporstat was tripped from the flooding. A simple fix and all is well.
Charles Garrity not only knows what he's doing. He's a very service oriented individual. I heartily recommend him!
Thanks, Charlie!Steve from Denver, CO1 -
You're welcome Steve, Thanks for the kind words. I must confess I felt guilty because we had talked you into flooding your boiler to start with. Glad your back on track with heating.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
