EZ-Gas burner does not start after amber checkout light
Steve Garson_2
Steve Garson_2 Member Posts: 712
My burner does not start after the amber checkout light illuminates. The motor does not start. Everything was fine until ten minutes ago when I flushed the boiler.
Any suggestions?
Steve
Steve from Denver, CO
  • RobG
    RobG Member Posts: 1,844
    Get Charles Garrity out there :)
  • Steve Garson_2
    Charles called me on the phone. I had just flooded the boiler to try to find a leak. There was none. He knew exactly why the burner wouldn't work: the Vaporstat was tripped from the flooding. A simple fix and all is well.
    Charles Garrity not only knows what he's doing. He's a very service oriented individual. I heartily recommend him!
    Thanks, Charlie!
    RobG
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,417
    You're welcome Steve, Thanks for the kind words. I must confess I felt guilty because we had talked you into flooding your boiler to start with. Glad your back on track with heating.
    cell # 413-841-6726
