Quiet Blower for a PF210?
AlCorelliNY
Member Posts: 63
in Gas Heating
Just changed out an original blower from a Purefire 210.
The new Fasco motors are the ones that replace the factory motors.
Problem is... It whines like a jet. No really, a jet engine.
Tried two other Fascos, same same.
I triple checked the part number, then I had someone else check them.
Does anyone have access to a factory style blower motor?
The original was very quiet.
Al Corelli
was the part #54258?
Did you check with advanced hydronic sales?
I'm guessing they are your Rep.
The only oem one I have access too is our temp boiler.0 -
Yes. 54258.
I'll call AH tomorrow.
Thanks.Al Corelli0
