Placement of piping on radiators
Jim Pompetti
Member Posts: 552
Is there any BTU loss , if piping of hot water rad is in any configuration ,other then both in the bottom of the radiator.
As long as the water can circulate properly thru all of the radiator, there should be no difference.All Steamed Up, Inc.
Consulting0 -
There is a reduction up to 50 percent if not piped bottom to bottom with hot water radiators. top to bottom piping leaves a dead spot directly below the inlet that is clear with an infrared camera. I will try an find them and post them here.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
