new one
j a_2
Member Posts: 1,804
Nice Job.
1 supply looks counterflow. If it is I would have dripped it to the wet return instead of bringing the condensate back into the header. Maybe it's just the angle of the picture making it look counterflow.0 -
Ur correct….But being a small sun rad , and the supply is at least twice the size if not more, than EDR…Pitched at 1/2 plus….And the last take off supplying 1 rad It will work just fine….FYI Those Everhot aqua boosters are great products for such, as this type application...0
Nice job- and I'll bet it runs much better!All Steamed Up, Inc.
Consulting0 -
@JA you know what your doing, it doesn't hammer and heats well I am good with that.
Thanks Steamhead, it does, what really helped is the addition of main vents….It never surprises me what you see out here….Will convert it to gas when the gas company brings in a new line….There a bit slow, up here….Steamhead said:Nice job- and I'll bet it runs much better!
- 87.1K THE MAIN WALL
- 58 Biomass
- 115 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
- 49 Industry Classes
