new one
    EBEBRATT-Ed Member Posts: 19,502
    Nice Job.
    1 supply looks counterflow. If it is I would have dripped it to the wet return instead of bringing the condensate back into the header. Maybe it's just the angle of the picture making it look counterflow.
  • j a_2
    j a_2 Member Posts: 1,804
    Ur correct….But being a small sun rad , and the supply is at least twice the size if not more, than EDR…Pitched at 1/2 plus….And the last take off supplying 1 rad It will work just fine….FYI Those Everhot aqua boosters are great products for such, as this type application...
    Steamhead Member Posts: 18,187
    Nice job- and I'll bet it runs much better!
    Consulting
    @JA you know what your doing, it doesn't hammer and heats well I am good with that.
  • j a_2
    Thanks Steamhead, it does, what really helped is the addition of main vents….It never surprises me what you see out here….Will convert it to gas when the gas company brings in a new line….There a bit slow, up here….
