Steam radiator for under sink cabinet mounting
My original kitchen radiator was mounted inside the sink cabinet (cabinet had a perforated grill in the doors for the heat distribution). I removed the radiator when I renovated the kitchen - now no heat in kitchen, which is only a problem when the temperatures get a really cold 20 degrees. Are there any steam radiators available that can be mounted under the foot kick plates of the cabinets?
thanks -cdm-
thanks -cdm-
I asked this same question a couple of years ago and was told no. I got an electric kickspace heater, but it's only good in the swing season. I'm looking for a wall steam rad. I think it's the only thing that will give enough heat unless you have hot water and could go radiant.Two-pipe Trane vaporvacuum system; 1466 edr
I could make one.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating1 -
Seriously!? That would solve a lot of problems. I responded to a post for a wall mount a while ago, but never heard back. Have you done this before ie. do you have any pics?Two-pipe Trane vaporvacuum system; 1466 edr
You can install indirect radiation either in the floor or in a wall with 1" iron fin tube. I am not much for picture taking.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
- 87.1K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
