control web base t stat for 2 stage heat
Sol Hydronics
Member Posts: 41
I know someone out here knows what thermostat is user friendly web base and can operate a 2 stage system. !st being radiant heat and second being fan coil air handler. the radiant has its own pump and the air handler has its own pump. Thanks and look forward to seeing how people are dealing with this.
Honeywell Prestige would be able to handle that. On the EIM board you can hook a 3 sets of dry contacts to the board and just program them to bring on as staging is needed. You set staging up by temp off set from set point. Are you running a pipe aqua stat for the fan?
Thanks for your idea. I will took into that thermostat and yes I was thinking of a pipe aqua stat to turn on and off the fan coil. Thanks0
Is it as easy as 'w' turns on the radiant and 'w2' closes a cube relay to turn on the fan coil pump? If so any thermostat could work like a nest. What am i missing?0
I am starting to think I might be dumb or this is something no one is doing. I sure wish someone would share please.0
I have an Ecobee t-stat in my shop that has two stages, web based viewing and adjusting.Bob "hot rod" Rohr
Thanks hot rod, could you please tell me if I have 2 stage , radiant is first and fan coil is second , this t stat could pull 2 separate relays for this?0
yes, but you need to be careful with wiring if you have a 24V source from two different loads. The directions show you how to wire it, either way.
Here are some examples, and they have good tech support.
https://www.ecobee.com/faqs/Bob "hot rod" Rohr
Yes you can do just that. get a double pole realy and when second stage calls it will bring on the zone valve and blower motor for the hydro air. It's easy to do. Your not the only one doing it.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
