Looking for creative way to cover up exposed copper piping in bathroom
josieT
josieT Member Posts: 53
I have these misplaced looking copper pipes running up through my bathroom. I'm curious if anyone has had this and knows of some kind of decorative cover I can get to cover it up. I know exposed piping is considered decorative too but not in this case.
  • icesailor
    icesailor Member Posts: 7,260
    A nice well made box comes to mind.
  • unclejohn
    unclejohn Member Posts: 1,833
    I would come out with tee and have a heated toilet paper roll thingy.
  • unclejohn
    But wait why stop there heated towel rack as well. When life gives you hot pipes use em.
    kcopp
  • KC_Jones
    KC_Jones Member Posts: 5,907
    Not to be to "smart", but the original steam pipe that would have been there was simply painted. You could do that. Or go the other way and "celebrate" the copper by polishing it to a high shine. As icesailor said boxing it in is really the only true cover up and that would require some more extensive work related to that tile floor and tile baseboard. At the very least you should consider sealing around those pipes at the floor which I am assuming goes into the basement? Probably some cold air coming up through there.
    2014 Weil Mclain EG-40
  • Fred
    Fred Member Posts: 8,542
    You can buy a composite column, with a base and cap, split then in half and put one half on each opposing wall as a decorative feature (hiding the pipes in the cavity of the column).
  • ChrisJ
    ChrisJ Member Posts: 17,060
    My downstairs bathroom has the plumbing to the upstairs bathroom run in a similar way, though I haven't actually seen the piping yet.
    Whoever did it, covered it using a cover made out of wood shaped like an L. Just two pieces of 1/2" x 6" or whatever it is nailed together and then mounted in the corner to cover the pipes.
    The only reason I don't hate it, is I'd rather have the pipes there than in an outside wall.
    hot_rod Member Posts: 26,563
    depends on your taste I suppose.
    If it were me I make it into a custom radiator of some sort. Celebrate the copper! At least some clever hooks to make it a heated towel bar.
    I seen line set covers used to hide exterior solar piping. It's a two piece plastic enclosure that would hold up well in humid bathrooms :)
    Crown moulding is tapered to fit across corners like that.
  • Fred
    I didn't see anything that indicates this is a steam or hot water heating run. It looks like maybe hot and cold water to another bathroom or apartment? Maybe the OP will tell us.
  • icesailor
    edited March 2015
    Well BOYS. From a Plumber, and a practical one at that, notice that nice piston flushometer on the wall connected to that toilet bowl? There will be descending green spots on that copper pipe from about 24" to the floor. The closer to the floor, the more the spots. Some say that it is the PTS to get them out.
    I'd go with wood box. And I'd find some arteest to paint Faux black tiles with white grout around the base. To match what is already there.
  • Abracadabra
    I'd be surprised if the Sloan valve would work adequately with only a 3/4" supply. Most buildings I've seen with Sloan Valves for the toilets had 1-1/4" supply. I'm guessing it's hot water for heat.
  • icesailor
    The piston flushometer does have the proper supply out of the valve. You can't see the inlet size. Even Diaphragm types have 1 1/2 outlets to contain the back rubber backflow device. It must be odd though because it doesn't line up with the center of the bowl. That looks like a high end house when it was built.
  • Harvey Ramer
    Harvey Ramer Member Posts: 2,281
    You can be as creative as you want, or your budget will allow. You could paint the pipes a flat color and then have a blacksmith wrap the pipes with wrought iron. You could create a "Jack and the Bean Stalk" scene. Or you could just have it wrapped with a pretty vine. I have seen blacksmiths wrap stuff like stair railings and posts. I think it looks truly amazing!
    You could also just build a box.
    You could do anything.
    SWEI
  • josieT
    These are great comments. I appreciate it. There was an old steam pipe there formerly replaced with supply/return heating pipes for my new and much despised hot water system. (Yes, I miss my steam system :( in case you haven't seen my previous posts). That old painted chunky steam pipe looked fine. Now I have these two skinny pipes and an exposed hole in the floor. Those copper pipes feed a sunrad to the floor above it. There is also no heat now in that powder room because the copper pipes can't generate enough to heat it. I am going to be putting a panel radiator in there at some point so that will need it's own supply/return from the basement below.
    Fred - what's a composite column?
  • josieT
    I think I found a price effective solution: polecoverings.com
  • kcopp
    kcopp Member Posts: 4,615
    You cold always use Azek to cover/ box around it and not worry about moisture .
  • icesailor
    Azek is nice. I took a piece of it and cut an inverted "U" in the bottom. Put it in so a sliding glass door could hold it in place so the cats could get into their Catio and entertain themselves looking out at the wild things that interest cats. But also keep the heat or cold in the heated space.
  • Fred
    It's a decorative column (either round or square) made of composite materials that aren't affected by moisture, steam, like wood. It does have to be painted when used as an exterior feature (due to UV rays) but you'd probably paint it regardless of where you use them. They come is plain round, fluted, square, tapered or straight (untapered).
  • Gordy
    Gordy Member Posts: 9,546
    Honestly if some thought was given to tuck the copper more in the corner I would just cut a 45 corner piece call it done with a like finish of the rest of the bath. Seems pretty small to do a box out taking up space in an already small area.
    If you like copper some of the above ideas are great ones hot rod is king on this.
  • tim smith
    tim smith Member Posts: 2,886
    Here is my tribute to copper pipe. Could just tie those 2 verticals to this and all would be cool (or warm as it is)
  • icesailor
    No copper next to a toilet.
  • tim smith
    Icesailor, the minimal amount of heat off towel bar does not create any sweating.
  • icesailor
    Its not the "sweating" I'm talking about. Unless you mean Male bladder sweating.
    Like my old High School Gym Coach used to tell us in Gym.
    BOYS!!. We AIM to please. So please aim.
    IYKWIM.
    Slant Fin makes special stainless steel baseboard covers for bathrooms so they don't corrode.
  • Paul48
    Paul48 Member Posts: 4,469
    I can't imagine what those cost. The perfed, powdercoated ones are over $20 a foot. They need to "get real"
  • icesailor
    @JosieT:
    Bathrooms never have enough storage space. That one looks like it is short in the space department.
    You'll have to work this out. Get one of those pre-finished toilet wall cabinets. The ones that fit over/behind toilets. The ones that hold towels and things with a cabinet for goodies. It screws to the wall so it doesn't fall over. Width for a tank isn't important because you have a flushometer valve. Get another straight wall cabinet for the side by the door. You'll have to adjust for a fit. Put something on the front to mount the paper holder to.
    Trust me if I tell you that you can go to any Lowes or Home Depot and find everything you need to cover or hide those pipes. The end result will be a better functioning bathroom. Its my experience that you only need to hide up 6' or eye level. After that, you don't notice it. You get used to it. And if you are worried about any guest coming and complaining about your exposed pipe, tell them not to look at it. If it is still too much, tell them they are welcome to leave.
    You can wallpaper those pipes. It's a witch to get it off. You can paint the copper too. Use oil based paint. Some paints don't like the expansion and might peel off
    It looks fine from where I am sitting, and I'm in Florida.
  • Gordan
    Gordan Member Posts: 886
    Is it just me or are those pipes not properly supported?
  • ChrisJ
    edited March 2015
    IYKWIM.
    Yuck.
  • icesailor
    Yuck?
    You're not a plumber/heater that can snake Slant-Fin covers out and off the wall to change the seriously rusted baseboard next to a toilet. Without draining the system and changing the baseboard element. That includes the brackets.
    Occupational hazard.
    You can only paint them so many times before no matter what you do, they still look like an old car driven on salted New England roads.
    Like plugged sewers. It comes with the territory.
  • ChrisJ
    icesailor said:
    Yuck?
    I've said it before,
    That's one of the main reasons I could never do that job. I don't even like laying on my bathroom floor working on my toilet and it's fairly clean and if it's not, it's mainly my waste!
  • icesailor
    That's what they make drop clothes and spray bottles of crud cutter for. And a box of Nitrile mechanics cloves. The blue throw away kind.
    Some might say that that was my bread and butter. s long as someone was willing to pay (and they were always willing to pay) I'd do anything. If I didn't, someone else would and I wouldn't be paid for it.
    A guy's gotta do what a guy's gotta do to stay ahead in life.
  • Snowmelt
    Snowmelt Member Posts: 1,457
    The easy way out would be slim duct and put it against the wall
