Free vent kits for Burnham Freedom boiler
jonny88
Member Posts: 1,139
Hi if you cant use the vent that comes with the boiler I have I have an approved two pipe adaptor to replace concentric vent.Enables you to use two pipes exhaust and air intake.I got plenty if you need let me know.
How ironic I'm embroiled in an 07 Freedom problem right now. It's got the concentric. Gaskets have to be overnighted from Burnham. That boiler kind of came and went pretty fast.0
Yep I got involved in a charity case where Burnham donated 90 of them to Sandy victims.I put in six so far no issues.If you need help or parts let me know.0
This guy was never serviced since install. Now they've got E02 lockouts. Blower sounds like a hamster wheel too. Thanks jonny, I may tap you if I can't get it!0
Of course it was never serviced who services boilers and then they expect miracles.I think the place that stocks the boilers has extra ones left over so I might be able to get you parts0
Thanks again. Waiting on Fedex, then tackling it later. Pins are TIGHT in that boiler!0
- 52 Job Opportunities
- 19 Recall Announcements
