Grundfos circulator
slick
Member Posts: 3
I just picked up a new grundfos circulator,it's a three speed with a check valve in it.this is my first time replacing one in my broiler and need some advice.i have flow control valves on all my zones,do I have to remove the check valve in this circulator before I install it.thanks Chris
-1
I'm guessing I don't need it,I'm a rookie at this boiler stuff.i would like an expert to jump in,before I start tearing stuff apart.0
If the flow control valves are working you could remove the check. It doesn't present much pressure drop if you leave it in.Bob "hot rod" Rohr
That's true (maybe) but if both checks are working, they can set up positive and negative zone between each other.hot rod said:If the flow control valves are working you could remove the check. It doesn't present much pressure drop if you leave it in.
Also, according to the performance curves published by Taco for (say) oo7 circulators, there is a significant decrease in performance with IFC's in place because their small size causes unwanted restriction.
He mentioned Grundfos, here is the curves with and without the supplied check. Very little difference in output, doubtful it would be noticed.
I guess the numbers don't lie,but looking at that check valve,you would think the flow would be restricted more then that.im taking it out,and thanks for the reply I feel better now.0
I was only going by Taco's published performance curves.
A Taco 007 without IFC's:
http://www.taco-hvac.com/uploads/FileLibrary/curves003-008.pdf
With IFC's: 17.5 GPM@8.75" of head.
Without IFC's, 23.5 GPM @ 9.75+' of head.
I'll take the flow & head over the restriction. Might make cavitation and put air in the system.0
- 15.8K Strictly Steam
