0-10v circ pumps
Any recommendations on a 0-10v boiler pump to be controlled by a Lochinvar knight boiler
  • bmwpowere36m3
    bmwpowere36m3 Member Posts: 512
    edited February 2015
    There some listed in the older I/O manual... however they are around $500 IIRC.
    *edit* I should note I believe those were ECM circs
    hot_rod Member Posts: 27,855
    Depending on the size, I see contractors using the Grundfos Magnas over at the Lochinvar VIP contest site
  • We have a complete lineup of "VV" 0-10Vdc circs in our 00 Series lineup. Been available for years (back when variable flow and energy efficiency wasn't as important as it is today).
  • bmwpowere36m3
    Any ECM 0-10V circs?
    For my setup (boiler primary loop, P/S), all I need is ~3-5 GPM with 1-2' head loss.
  • Nothing today sorry (patience please).
    Back in my WILO days that would have been a perfect application for their little 24 Volt Geniax...
  • SWEI
    SWEI Member Posts: 7,342
    In Europe, anyway.
  • Yep.
    there are a good number of the small PWM circs available across then pond of various brands. We use some of these Wilo in the Satellite units we build for Euro markets, and some with Grundfos brands.
