Forced Hot Air with Hydro Baseborad radiators - Can I do both?
If anyone has heard of drawbacks of using both together I would really appreciate the feed back.
would it cost more to run both? as the Forced Air is a year old and was thinking of adding radiators to keep the warmth feeling longer (should have just gone that way from the beginning but these extra cold winters are hard)0
Forced hot air or hydro air? I.e. do you have a boiler?0
Just out of curiosity is this the same house you posted about a couple years ago that had a steam heating system?0
yes it was!! the plumber convinced me to just go the forced hot air to save some $$ and it's been OK on the normal days but in the extreme cold days it's not so good -- I can easily supplement the Forced Hot Air with some Radiators linked to the same Thermostat? (Maybe) - just to get better comfort. -- Is this just crazy to do?0
It is Hydro Air I guess - the Boiler works to heat the unit that pushes the air0
I don't see why not... but without more systems details (current piping, supply temps, etc.) it's all speculation.0
Yet another professional convinced a customer to rip out a system just because he didn't understand it.
That shot is by no means aimed at you @FMA124 .
I don't know that I'd run both but you could always have some form of hydronic heat installed (steam, radiant, baseboard etc) and then keep the hot air as a backup system.
I wouldn't run both at once though if it was me.
Another option may be to spend the money on tightening up the house. Eliminate drafts etc as forced hot air doesn't tolerate such things.
thank you! I am working on tightening up the house but since it's a concrete structure I keep finding ways for the cold to get in. I will be using the Baseboard radiators just in the first floor where it is easy to install. I figure if the Boiler is on producing hot water one more loop should not make much difference in energy use. Especially if it gets the room warmer quicker and would stay warmer.
A little extra work for me but I will be doing this myself and it will be a learning experience. My Dad has done this many times and will be there to make sure I don't mess up.0 -
ChrisJ
I had about 6 plumbers come in to look at my Steam heat as I needed two more radiators upstairs and none of them wanted to touch it. They ALL recommended I go a different way and it was more my Wife that wanted a clean NO Baseboard look in the house and the Plumber told her it would save us 19k -- still not sure how it was 19k as I'm going to do it for much less now but just trying to fix an uncomfortable problem - the house is fine just in the extreme cold days it's bad0 -
@FMA124 Curious, where are you located?FMA124 said:ChrisJ
I had about 6 plumbers come in to look at my Steam heat as I needed two more radiators upstairs and none of them wanted to touch it. They ALL recommended I go a different way and it was more my Wife that wanted a clean NO Baseboard look in the house and the Plumber told her it would save us 19k -- still not sure how it was 19k as I'm going to do it for much less now but just trying to fix an uncomfortable problem - the house is fine just in the extreme cold days it's badSingle pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Westchester NY0
Chris J -- Any specific reason you would not run both at the same time?0
Just seems like it would be unnecessary wear and also cause problems.FMA124 said:Chris J -- Any specific reason you would not run both at the same time?
Of course, you would know for sure after trying it. I don't think it would hurt anything. I'll admit I hate forced hot air so that might be another reason I'm biased against running it.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Thank you - I am going to try both to see how it works as I figure Baseboard should stay warmer longer and warm the concrete much more than the forced air - and the Forced air should move the heat around the room much quicker
Do you think keeping both on one thermostat makes sense or keep them separate ?0 -
I don't know about heating the concrete... baseboard (fin-tube) mostly puts out heat via natural convection. Basically like forced air without the forced air
I guess what I mean is that it will be more concentrated against the floor and walls instead of just the air.bmwpowere36m3 said:I don't know about heating the concrete... baseboard (fin-tube) mostly puts out heat via natural convection. Basically like forced air without the forced air
As long as you guys don't think it will double my energy use or hurt, I think I am willing to have fun doing the work.0
- 87.2K THE MAIN WALL
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 75 Pipe Deterioration
- 6.4K Radiant Heating
- 15.6K Strictly Steam
