Abandoned Vintage Boilers - some photos...
ChicagoCooperator
Member Posts: 355
Today I got to inspect the basement of a historic Chicago building which had these abandoned boilers in the basement and I thought that some of you might enjoy seeing them. The steam was abandoned when the building was rehabbed 30+ years ago, however the boilers were left in place and have remained ever since. The original flue is still in use for water heaters. The basement is fairly shallow with the sidewalk being even with the top of the ceiling you see in the photos. The building engineer told me they were coal, converted to oil and then gas. He said that the oil tanks had been in place until the renovations and had taken up a big chunk of the basement and that the coal bunkers had been elsewhere, partially under the old sidewalk vaults. Anyways, enjoy.
1
Very cool! Thanks for sharing!0
Any chance you could get a shot of the rating plate for the Type C? We tore out two of them (1937 & 1947, 3.85MM BTU each) on a job a few years back and I'm just wondering how similar this one might be.0
American iron! Those castings are much better than anything cast iron we have these days it seems.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
Those things are built like tanks...but I'm really grooving on that stylized font. Such care with the littlest details.Two-pipe Trane vaporvacuum system; 1466 edr
Love the doors. If I had a house big enough they would make a great wall decoration....with a little wall reinforcing!0
I have two sets of doors with frames. Figure they would look great behind the bar -- perhaps even chrome plated.0
You can tell the lettering was done by hand,in those days, and not by computer controlled milling machine. It has such life in its appearance, and execution.
Great stuff!--NBC0 -
If we get the job there I'll be sure to get more pictures. Depending upon what way we go with the project, one of the boilers might get removed and might have to be chopped up for it (only place foundation is not at the basement floor level). I'll sell pieces to you guys (or the building maybe).0
I have taken care of a LOT of those old Kewanees on Edwards AFB California.........almost without exception that is the heating plant of choice for the hangars down there 8-)0
I have a door off a residential Birtchfield that I was planning to do just that with 8-)0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
