8-Way boiler treatment
JWH
JWH Member Posts: 13
Is it safe to use 8-way boiler treatment in a system with a domestic hot water coil?
    hot_rod Member Posts: 27,459
    check with the manufacturers label or MSDS sheet. Most of the hydronic conditioners are formulated to be safe, or very low toxicity.
