The REST of the story...
Mark Eatherton
Member Posts: 5,853
Wallies, WAY down the wall was the discussion about how to raise a boiler off the ground onto a cinderblock pedestal. Instead of adding to the old thread, I will finish adding the critical "Teeter totter" pictures to this thread. Enjoy!
ME
ME
1
Don't throw that teeter totter away; there will be another time you need it. Put it in the basement with all the other stuff.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Always loved Paul Harvey.0
Because if you remember that it is there, when you spend the morning getting it out, it will be 6" to short to do the job.Don't throw that teeter totter away; there will be another time you need it. Put it in the basement with all the other stuff.
The "Rule" is that it will never be 6" too long. You'll need to buy the material to build another one that fits.
hey mark was reading your post ,we recently did one on a pedestil but instead of your teater tooter we brought a small pump jack and inserted some deep versa bar it was wonderful and much safer and easier then making a wood ramp .Ended up using quite a few times in the last couple of months it was a good investiment and is easier then screwing your back .Peace and good luck clammyR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Alan, you know me too well... I have already recycled the teeter totter. It is now a wall beneath my deck where my thermal battery system will be placed.
Ice said "Because if you remember that it is there, when you spend the morning getting it out, it will be 6" to short to do the job."
Ice, that's what she said :-)
Clammy, nice to see your words. This ramp idea is not for everyone, and if I could have, I'd have used an engine hoist to get the boiler up there, but this worked for me (I work alone) in this application. It's not for everyone, only those in a jam with ingenuity :-)
I have a good friend (Der Heatmeister) who has a break down engine hoist that I could have used, IF there had been a solid surface all around the base, but alas, there was not. He too works alone for the most part, and devised his hoist for placing mod cons on walls. It's capable of lifting 1,000 pounds, so it wouldn't have been an issue.
METhere was an error rendering this rich post.
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
