Out of curiosity...
Jack
Member Posts: 1,058
in Gas Heating
In your area, what is the standard gas pressure supplied by your local utility?
Pounds to the regulator/meter ( usually at the alley) then 4 ozs---7" WC thru 70 to 100' UG 1 1/4" svc pipe to house/building. Only 4 ozs inside any building. (except power plant)0
Same here 4-6 w.c0
