Modbus monitoring of residential boiler
agt24
Member Posts: 2
I’d like to try some basic modbus charting similar to what Eric Sandeen has done here:
http://sandeen.net/wordpress/energy/residential-boiler-monitoring-via-modbus/
but my boiler does not currently support modbus. It’s a Weil-McLain HE II and the control board is a Gold GV Model 1013-200. I'm looking for suggestions for a control board I could swap in that would support modbus readout.
Any ideas?
Any ideas?
Maybe this would work:
http://www.welserver.com/
or I use one of these:
http://www.controlbyweb.com/x300/
Love to hear how it works out.
Cheers:
TimWinter Park, CO & Arvada, CO0 -
Thanks, Tim. But I'd like to chart (and possibly control) the boiler operating variables (like burner firing rate) and for that I need a modbus interface. I've worked with a commercial Lochinvar boiler that lets you do this. Now I'm curious if I can do it with my residential boiler, too, without replacing the entire unit.0
In short, no. That's a 15 year old fixed firing rate boiler, so how would it be able to tell you anything about its firing rate?agt24 said:my boiler does not currently support modbus. It’s a Weil-McLain HE II and the control board is a Gold GV Model 1013-200. I'm looking for suggestions for a control board I could swap in that would support modbus readout.
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 55 Water Quality
- 47 Industry Classes
