What kind of radiator is this?
JPL
Member Posts: 16
Does anyone know what this type of hot water radiator is called, and if they are still available somewhere? I have a couple in an older home, installed in recessed areas. They measure 13" high, are 9-1/2" deep, and the sections are 10" wide. They put out a lot of heat. I am looking to add a radiator to another area of the home and am constricted in space. I need to find something that will put out at least 5000 BTUH, but will fit in a 17-3/4" high space (due to window opening) and is less than 50" wide (including piping). I thought if I could find one of these somewhere, it would do the trick. Any help is sincerely appreciated. Thanks.
Cast iron convector element. You might try http://www.ocsind.com/cast-iron.php0
Thanks for your help. That gets me started.0
- 87.2K THE MAIN WALL
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 75 Pipe Deterioration
- 6.4K Radiant Heating
- 15.6K Strictly Steam
