Ventrite to Gorton Conversion
mcvetyty
mcvetyty Member Posts: 50
edited December 2014 in Strictly Steam
Hello - Can someone please tell me what the closest Gorton # equivalent would be to a Ventrite adjustable vent at setting #4? Thank you!
  • Mark N
    Mark N Member Posts: 1,144
    Ventrite' s are very high quality vents, why change unless they're nonfunctional. A Gorton #4 is close to same venting rate.
  • mcvetyty
    Thanks Mark - Changing primarily because the ventrite on this particular radiator (bedroom) is whistling slightly while it heats up and keeping me up at night. My experience is the Gortons produce a more sleep inducing wooshing noise that I am hoping to dream about!
  • Mark N
    If the vent is whistling you don't have enough main venting. Also try cleaning the vent rite with vinegar.
