Used Caleffi Series 548 1.25" Hydro Seperator
BigRob
Member Posts: 332
Unit is in good shape. It was used for a little more than a year. You will need 4 new fiber seals.
$250 + shipping from California.
Is this npt or sweat? And do you still need an alpha? I have one I bought for a job and ended up using a 15-58 instead.0
I'm curious how you come across a used sep? I can mail fiber gaskets to the new owner.Bob "hot rod" Rohr
Very nice of you, Rod! I'll PM the address to you.hot rod said:I'm curious how you come across a used sep? I can mail fiber gaskets to the new owner.
I swapped in a SEP4 to our condo complex boiler room. Past experience and a bucket of iron oxide has me paranoid about oxygen. The 548 was installed after all of that drama- just wanted more air removal and the magnet. Overkill is underrated.0
- 123 Chimneys & Flues
