Economizer Training
Harvey Ramer
Member Posts: 2,239
Looking for a book that will give me a comprehensive training course on economizers. Should cover various different controls and their respective terminal functions.
Thanks
Harvey
Thanks
Harvey
Google honeywell economizers manual they had a pdf that you can down load that is very helpful with desing n trouble shooting.5
Thanks Don! I downloaded Honeywell's "Design and Application Guide". I read it today, all 265 pages. Very good read and quite informative. I loaded it onto my onedrive so I can access it from my smartphone while out in the field.
We're in business!
Harvey0 -
No problem Harvey glad i can help.Lets hope you can talk them in to some free cooling.It seem as of late all you find now on a roof top unit is a manual air damper to address the fresh air issue and most of them are completely shut off.pay close attention to the co2 issue n always keep in mind cold dry air is what you want to use in the winter to control humidity.good luck.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
