Heat loss, what size boiler do I need?
DanHolohan
Member, Moderator, Administrator Posts: 16,696
in Gas Heating
This discussion was created from comments split from: Heat loss, what size boiler do I need?.
Retired and loving it.
I just did an oil-to-gas conversion on a very similar house. Some observations:
1) I used the Taco FloPro software to model the system and get loads. Unless you are very familiar with HVAC systems, I don't recommend it - it is NOT very user friendly. On the other hand it lets you model the room loads very accurately.
2) I chose a design temp lower than recommended. While I agree with the above posters that design days happen only a small percentage of the time on an historical basis, that might be changing. I won't get into Global Climate Change here, but I will say that, over the past 3 winters in my area, we have had pretty long stretches that were below the ASHRAE design temps. Whether that's an outlier or a trend I don't know, but I'll say that I did let the prospect of 2 weeks of a chilly house with the boiler running full out may have swayed me.
3) Someone mentioned a gas gun conversion. I wish I had looked more closely into that, but when I read that Burnham didn't recommend it I dropped the idea. But if it's possible, and you currently use a tankless coil, look up IceSailor's Electric HW Heater to Storage Tank Conversion. It's what I will be doing at my place as soon as I can wrestle the old electric tank I have from it's location.0
- 123 Chimneys & Flues
