Gauge source?
JohnNY
Member Posts: 3,324
Hello all,
I need 0-15" w.c. and 0-3 psi round dial gauges and was hoping for an internet source.
Share your source, please.
Thank you,
JC
Thank you,
JC
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes
Classes
Amazon
0 thrrough 3PSI seem scarce but heres one...
http://www.amazon.com/WIKA-9851836-Pressure-Dry-Filled-Connection/dp/B002710HTO/ref=sr_1_21?s=industrial&ie=UTF8&qid=1416447211&sr=1-21&keywords=Gauge+0-3+psi
Also EBAY.0 -
Johhny,
0-15WC I usually get from Grainger:
http://www.grainger.com/product/MILJOCO-Pressure-Gauge-2RHE4?searchQuery=2RHE4
http://www.grainger.com/product/Press-Gauge-18C783?opr=APPD&pbi=2RHE4
0-3PSI I get from my local supplier but here's some from Grainger both bottom and back connection:
http://www.grainger.com/product/Pressure-Gauge-WP51585/_/N-bdk?s_pp=false&picUrl=//static.grainger.com/rp/s/is/image/Grainger/4FLZ2_AS01?$smthumb$#nav=/product/Pressure-Gauge-WP51585/_/N-bdkZ1z0us7m?R=18C789&_=1416450253965&picUrl=%2F%2Fstatic.grainger.com%2Frp%2Fs%2Fis%2Fimage%2FGrainger%2F4FLZ2_AS01%3F%24smthumb%24&redirect=Pressure+gauge&s_pp=false0 -
I bought mine from Valworx.
http://www.valworx.com/category/low-pressure-gauges-25-lower-mount0 -
My 3.0 Gauge is made by Wika and I thought came from a place called "The gauge store" but I can't find that anywhere. That was back in 2011 so maybe something changed. I did find it at amazon though.
However, my more recent gauge came from Dwyer. Model : LPG4-D9122N Low pressure gage, range -8-0-16" w.c. (-2-0-4 kPa).
http://www.dwyer-inst.com/Product/Pressure/SinglePressure/Gages-Dial/SeriesLPG4
Dwyer does have a 0-15" gauge as well : LPG4-D8122NSingle pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Supplyhouse.com? Used to be PexSupply.0
Chris I think the gauge store is now Valworx. Kind of like supplyhouse used to be pexsupply.ChrisJ said:My 3.0 Gauge is made by Wika and I thought came from a place called "The gauge store" but I can't find that anywhere.
Thanks, guys. Good suggestions here. Larry, that Ashcroft gauge looks like a thing of beauty. Mine get bounced around a lot and I could use a step up in quality.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Classes0 -
Aaaand we broke them.
"Not enough storage is available to process this command. "0
- 110 Chimneys & Flues
- 106 Geothermal
- 978 Plumbing
- 387 Solar
