Please help identify this boiler and Sq.Ft. of Steam output.
JohnNY
Member Posts: 3,326
Waddayathink?
Is that 1344 number the sq. ft? It seems low.
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes
Classes
I think I found the boiler:
http://boilers.easco.com/item/all-categories/-pressure-steam-and-hot-water-scotch-marine-boil-2/fst-32
That looks like the max firing rate mbh0 -
FST-32, SERIES FST - LOW PRESSURE STEAM AND HOT WATER SCOTCH MARINE BOILER
http://boilers.easco.com/item/all-categories/-pressure-steam-and-hot-water-scotch-marine-boil-2/fst-320 -
Damn. You guys is good. Many thanks to both of you.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Classes0 -
I hope you are not just sizing a replacement from the old boiler, without doing either a heat-loss, or radiation survey!--NBC0
Of course not. I'm writing a report detailing the inconsistencies between the system requirements and the steam supply and how it relates to energy consumption and maintenance costs.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Classes1 -
I hope we can read it sometime.
4 pressuretrols-is that a three stage burner?--NBC0
- 87.1K THE MAIN WALL
- 58 Biomass
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
