is there a special programable thermostat for 4 zone boiler heat system
vecbrraaa
Member Posts: 2
Short answer, no. If you give a little more detail, we can offer you some ideas.
Basically, you have 4 zones, in 4 locations, therefore you need 4 thermostats.
Most programmable thermostats could/should work, but keep in mind usually with programmable thermostats, the user typically wants to employ setbacks, which depending on your system and your emitters might not be a good idea to employ deep setbacks.There was an error rendering this rich post.
5 -
Look into the Tekmar 400 series House Controls.5
This might work for you if your piping is set up right http://www.ivar-group.com/LR_DMS_ECommerce_Portlet-portlet/enhancedDownloadEngine/IVAR/Document/COVER/306600/Equicalor US.pdf?time=1416086858314
Harvey5 -
thanks for the info, very useful0
- 87.7K THE MAIN WALL
- 127 Chimneys & Flues
- 121 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
