Skimming port
Hi I'm new to this blog. I have a BurHam IN gas fired steam boiler one pipe heating system. My boiler doesn't seem to have a skimming port I provided a few pics of my boiler. I want to know how often should skimming be done and can anyone describe what steps I need follow? And if I don't see a skimming port where should it be located? https://us.v-cdn.net/5021738/uploads/editor/f0/398mhp4dkbe2.jpg
https://us.v-cdn.net/5021738/uploads/editor/c8/llvforkibqf9.jpg
https://us.v-cdn.net/5021738/uploads/editor/wx/6o1i0bbtj18o.jpg
  • j a_2
    j a_2 Member Posts: 1,804
    Bob Thats good advice….I do not like water feeders…I will only install them in special cases….They are not automatic water feeders, they just cover up problems….If and when i did install them they had a meter attached or a inner counter...
  • Steaming101
    Steaming101 Member Posts: 30
    tks for all the replies! So I'll do the skimming than I should produce steam, I'm I reading this correctly? Also I shouldn't have the automatic water feeder on?
  • Steaming101
    When you skim the boiler should the boiler be on or off? And also should this boiler be service at least once a year?
  • Steaming101
    Fred when you use the pressure relief valve to skim your boiler do you hook anything to the port (hose) or do you let the water just drip into a bucket? Tks for your help
    Inmar
  • Gov
    Gov Member Posts: 1
    I have a boiler with a 1 1/2" reducer to 3/4 shutoff to skim.
    iI want to change it to 1 1/2 black 7 inch or so nipple and cap. its approx 2012 sieres 2 osb. How do you know if bushing or plug wont come off or when to stop trying?
    or too risky and leave it.
    Thanks for the help.
    EBEBRATT-Ed Member Posts: 19,602
    Pictures.
