PH meter
Steve_210
Steve_210 Member Posts: 664
Looking for a recommendation on a good pH meter.
Used to check pH levels on the condensing boilers with aluminum heat exchangers.
To measure pH level of the condensate after passing through the neutralizing tank.
And also to measure the pH levels of the water in steam boilers.
I would rather not mess with litmus paper, more than happy to spend the money on something that will work.
Thanks for any help
