sentinel x 400
Danscrew
Member Posts: 130
Going to do my first heat x changer cleaning on my WM97 mod con. I know its hard to tell the heat exchangers condition before I open it up. Would You think it will be necessary to use Sentinel x 400? What else can I use in its place For cleaning ?
Rhomar Hydro-Solv should work. Fernox also has options, though I'm less familiar with those.0
Does the installation manual have an answer? My W-M boiler with aluminum heat exchanger requires Sentenel X-100. The stainless firetube ones my require something else. The installation manual should say. Or their tech rep should know.
