Help finding a fitting
SWEI
Member Posts: 7,348
I'm striking out at the supply houses trying to find what seems like a simple thing: A concentric copper or brass reducer with a 3/4" sweat internal size and an NPT (whatever size) male outside. Kind of like a T x S PVC bushing, but in copper or brass.
Anyone know who might make these?
thanks~
thanks~
That looks like a standard 3/4" MA.
Turns out Brasscraft makes what I'm looking for.
http://www.brasscraft.com/PDF/300.230_PSA_Series_MIP_x_Sweat_Adaptor.pdf0 -
Ah, what are you up to?Retired and loving it.0
Installing a Pasco 1450W thermowell into an IPT tee. Nobody makes thermowells with probe lengths under one inch, plus they are all set up for 1/4" OD thermistors.
Pasco uses them for dial thermometers. We use them for pipes under 1-1/4", and they also happen to fit the oddball 3/8" OD 12k thermistors that some of the boiler manufacturers supply. Nobody stocks 12k thermistors with 1/4" bodies.0 -
http://www.supplyhouse.com/Cello-WP4-2-12-3-4-FTG-x-Male-Street-Adapter-1044000-p
I think that is what you are looking for? Street 3/4 to 3/4 male NPT?0 -
Sloan Urinal Adapter kits cost a lot more money as the kit than the single fitting alone. At $60.00 per hour equals $1.00 per minute, its usually more cost effective to buy the whole kit to get the fitting than to go on a parts safari to the parts supply houses and find that they don't have what you want.
Those round trips to the supply house can really hurt the bottom profit line.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
