Cast iron rads for sale near Pottstown PA.
Novagen_Ed
Member Posts: 45
All removed from working 1 pipe steam system in 2011, following sizes are H x L x D. All are Crane unless noted. NO SCRAP DEALERS please! , Cash and carry, pickup near Pottstown PA. (QTY 1) 19 x 39 x 8 (16 sections) $350 (QTY 2) 24 x 36 x 8 (15 sections) $300.00 each or BOTH for $550.00 (QTY 1) 19 x 32 x 7 1/2 (13 sections) $275.00 (QTY 1) 24 x 24 x 6 (10 sections) $250.00 (QTY 2) 36 x 19 x 6 (8 sections) $250.00 each or BOTH for $450.00 (QTY 1, unknown MFG.) Wall hung 24 x 26 x 2 3/4, with 2 brackets, $225.00
LOL! Well, I am trying to find them a good home......
Hi. I know you wrote it was a one-pipe system, but could the wall hung rad work with two-pipe? It's hard to see the details.Two-pipe Trane vaporvacuum system; 1466 edr
Twinned, staged Slantfin TR50s piped into 4" header with Riello G400 burners; 240K lead, 200K lag Btus. Controlled by Taco Relay and Honeywell RTH6580WF-1 -
Hi vaporvac. Thanks. I posted 2 more pictures, left and right ends of the rad. Looks like each side has a top and bottom tap, each with a hex head plug except, of course, bottom left.0
I'm going to go get an exact measurement. How much do you reckon it weighs? Also, do you know how far out the bracket extend; I only have about 6" behind the door.Two-pipe Trane vaporvacuum system; 1466 edr
Hi vaporvac. The brackets measure 3 1/4 inches deep, back of flange to tip of hook. I can actually lift this one, so I figure the weight to be 100 Lbs or less....0
What is the dimension from wall to face of radiator? I have a similar situation.0
Hi keylargo1. The brackets stand the radiator's front face out about 3 inches from the wall. The front of the bracket "hooks" are an additional 1/2 inch thick beyond radiator's front face.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
