Cast iron rads for sale near Pottstown PA.
All removed from working 1 pipe steam system in 2011, following sizes are H x L x D. All are Crane unless noted. NO SCRAP DEALERS please! , Cash and carry, pickup near Pottstown PA. (QTY 1) 19 x 39 x 8 (16 sections) $350 (QTY 2) 24 x 36 x 8 (15 sections) $300.00 each or BOTH for $550.00 (QTY 1) 19 x 32 x 7 1/2 (13 sections) $275.00 (QTY 1) 24 x 24 x 6 (10 sections) $250.00 (QTY 2) 36 x 19 x 6 (8 sections) $250.00 each or BOTH for $450.00 (QTY 1, unknown MFG.) Wall hung 24 x 26 x 2 3/4, with 2 brackets, $225.00
  • RobG
    RobG Member Posts: 1,844
    Uh Oh, you just made Steamhead an angry man! :o
    Novagen_Ed
  • Novagen_Ed
    Novagen_Ed Member Posts: 45
    LOL! Well, I am trying to find them a good home...... ;)
  • vaporvac
    vaporvac Member Posts: 1,520
    Hi. I know you wrote it was a one-pipe system, but could the wall hung rad work with two-pipe? It's hard to see the details.
  • Novagen_Ed
    Hi vaporvac. Thanks. I posted 2 more pictures, left and right ends of the rad. Looks like each side has a top and bottom tap, each with a hex head plug except, of course, bottom left.
  • vaporvac
    edited October 2014
    I'm going to go get an exact measurement. How much do you reckon it weighs? Also, do you know how far out the bracket extend; I only have about 6" behind the door.
  • Novagen_Ed
    Hi vaporvac. The brackets measure 3 1/4 inches deep, back of flange to tip of hook. I can actually lift this one, so I figure the weight to be 100 Lbs or less....
  • keylargo1
    keylargo1 Member Posts: 2
    What is the dimension from wall to face of radiator? I have a similar situation.
  • Novagen_Ed
    Hi keylargo1. The brackets stand the radiator's front face out about 3 inches from the wall. The front of the bracket "hooks" are an additional 1/2 inch thick beyond radiator's front face.
