Pump Lifespan Question
nycpa
Member Posts: 108
Hi, From experience what do you guys think is the average lifespan of a circulator pump for a hot water loop from a steam boiler, cast iron versus bronze verses stainless steel. I know that stainless steel and bronze have a longer lifespan do to being able to handle the corrosive nature of steam boiler but what about the other parts of the pump that might fail and render the entire pump useless. Thanks.
Pumps
We've seen cast-iron pumps fail every month, like clockwork. Brass pumps...never seen them fail from corrosion. The 3-piece motors and couplings can go bad every 5-10 years.0 -
gravity
Is it possible to do a gravity hot water loop off of a steamer?Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
yes
If loop is above the water level of boiler. Don't use flo checks. If zone is overheating then throttle the isolation valves a bit. Will take some trial and error. Would leave a circulator in place, just in case loop calls and steam portion hasn't been calling for a while.0
