Old furnace, change of repair?
kpunch
kpunch Member Posts: 4
Hi, I just bought an old house last year, with an bi-energy heater. It worked through last winter,but it seems not switching correctly between electricity and oil, When it worked with oil it does not stop at temperature, while it works with electricity it takes long time to warm. It cost me a big bill for oil and electricity. I changed the thermostat, but seems makes no difference.
The heater is branded 'Brock', with model number L0-1MQH' and 'QH-1AR5'. I have limited knowledge of heater, can't even tell what year is the furnace made. Is it worth repairing or shall I replace it? Any advise is welcome.
    Steamhead Member Posts: 18,196
    Sure it's not
    a "Bock"?
    Consulting
  • kpunch
    yes.
    the brand is ‘Brock’, as attached. Any idea?
  • icesailor
    icesailor Member Posts: 7,260
    Eh?
    Its probably one of these. Canadian.
    http://www.wolseleyinc.ca/businesses/hvac/brock/manuals.htm
  • kpunch
    yes,
    but could not find the right model? Are you familiar with it?
  • icesailor
    Familiarity:
    I never in my life heard of one. I thought it might be made by Bock. I found it on the Internets. Maybe a phone call to the number listed on that link would give you what you need.
    Many Americans are unaware that there is a vast world on the other side of our borders. Like Canada, where it is far colder than the USA. They like to be warm too. Many Canadian Manufacturers do not want to deal with the USA BS of UL Listing. They have their CSA which seems to be slowly supplanting UL as a testing Standard. In many ways, they are way ahead of the USA and the Wall Street Crime Syndicate and their Bankster Subsidiary.
  • kpunch
    Thank you for your advice.
    From your experience, do you think the problem I described is major or costly to fix?
  • icesailor
    Quandry:
    It sounds like a service issue, not a replacement issue. Best determined by a qualified heating professional with his eye upon it.
