Furnace to small service call
DCD87
Member Posts: 2
in Gas Heating
living in the northeast i am yet to go on a service call in the winter where the furnace/boiler was undersized. I have been on many service calls where the baseboard was not adequate for the space. I believe this says something on how equipment is sized.
Growing Emitters:
The best way to grow undersized emitters is to decrease heat loss.
And raise the system temperature.
Wait for warmer days.0 -
Started in 1978
I haven't seen one ever!0 -
sizing
Cant say the same, seen quite a few steamers undersized….0 -
Sizing
Yes, it certainly does say something about how equipment is sized. Usually over sized.0 -
Over and Under:
I've seen a lot of oversized boilers with undersized emitters when the OAT hit design temperature. Usually because of cold air infiltration, warm air leaving. Tightening up the building usually resolved the issue, made it comfortable and saved a ton of money.
Sometimes, just raising the system temperature.0
