Homeonwer
Ros
Member Posts: 3
I had a new steam boiler with an extension for hot water baseboard heating installed in October 2013 and need an expert opinion as to whether the system is properly sized and piped to determine whether I have a claim against the company that installed the equipment. The expert needs to provide a report and be available to testify if a court action is needed.
Boiler
Where are you located?0 -
Steam Heat
Looking for expert witness.0 -
Steam Heat
I live in Westfield, NJ Union County.0 -
Improper installation
Why not post some pictures first here, and then get comments on the installation.
Is this one-pipe, or two-pipe?
Describe all the symptoms you are having, if you have been able to run the boiler.
Frequently the court case ends up with the installer being given a chance to rectify his mistakes.
A description of what should have been done , included in a letter from your lawyer would probably get some response.
Do a search for "clammy", as I think he is from your area.
This is probably the busiest time for steam professionals, as people begin to fire up their systems.--NBC0 -
NJ
I just sent you a private message. Just posting here in case you didn't get it. I service your area. Call or email any time.0
- 50 Industry Classes
