rework closed loop to drainback
catbird
catbird Member Posts: 1
currently have closed loop system with 5 4'x8' collectors fed by hartell solar coupled pump. need best pump option for 8' head, solar driven if possible, in drainback setup.
  • SWEI
    SWEI Member Posts: 7,348
    8 feet of head
    is right on the edge for a Laing Thermotech D5 http://documentlibrary.xylemappliedwater.com/wp-content/blogs.dir/22/files/2012/07/BR-20A.pdf
    hot_rod Member Posts: 27,058
    Lower the lift head
    By raising the drainback tank as high as possible Those DC solar pumps are not available in a wide selection
  • matt_sunwaysolar
    matt_sunwaysolar Member Posts: 61
    marchpump.com
    March Pump has some of the highest head ratings that I have seen in 12V and 24V powered pumps. I believe the 809-HS model has the most appropriate capabilities.
    It is probably true the most important thing can do is to decrease the height that fluid has travel vertically.
    With 8' of head at 5gpm, you can run an 115V circulator at about 80 watts max. (Less if you use a variable speed controller.) Something like the grundfos up15-58fc.
    ECM circs
    are another option if you have 120V. Maybe pump that system with17W on the Alpha.
    On dual pump, high lift head, drain back I have paired and Alpha with a 15-58. Start the siphon with both running and drop back to the Alpha at speed 1 or 2.
