Weil Mclain Ultra 155 Leak
NJMan873
NJMan873 Member Posts: 2
I took the cover off my boiler and found that it was leaking from one of the black bolts that have a hex head. Is it just a matter of resealing or replacing the bolt or is it more serious? Also what size are the hex head bolts? Thanks
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,577
    Leaky cover
    What about posting a picture?
    You won't know how serious it is until you take it apart. Some professional help may be needed here. Is there anyone who does the yearly service on this who could have a look?--NBC
  • NJMan873
    Pics
    Here are the pics of the unit. Thanks
  • Brp814
    Brp814 Member Posts: 22
    Ultra Boiler servicing
    Water chemistry is very important for the Ultra boilers, because of their aluminum heat exchanger. The bolt size for the front bolts is 10mm. Has the boiler been serviced on an annual basis? Annual maintenance is also very important for this boiler too. There is a maintenance kit that Weil/Mclain makes, and it includes everything to service the boiler, even extra nuts/studs.
    Let us know how you make out. I have serviced a number of these boilers, and we have not had any heat exchanger leaks.
  • Jean-David Beyer
    On my Ultra 3 80, the nuts need an 11mm socket.
    I wonder if we are talking about the same thing.
    I am talking about the nuts that hold the front cover of the heat exchanger onto the main body of the heat exchanger.
    Or are you talking about something else? Like the cap screws in the main body of the heat exchanger, the ones that take an Allen wrench?
