Moline System in Moline, Illinois
Dave in QCA
Member Posts: 1,806
My friend who posts under "Boiler Wrestler" sent me a picture of a job he is working on in Moline, IL. It just happens to be an old Moline System and still has the ejector and condensing loop. We don't see that too often, even around the Quad Cities
Here is a picture the excellent install with 3" risers, drop header on a Weil-McLain EG55. Should make some real dry steam for that system.
And as usual, BW's excellent work is like a pretty painting.
Dave in Quad Cities, America
http://grandviewdavenport.com
Nice work
Any pix of the original Moline bits by chance?0 -
Moline bits
Not the best photo,but something. The ejector fitting and a short condensing loop remained. The system was knuckleheaded with returns tying in above the water line including the condensing loop.
There are quite a few Moline Systems around but usually not complete. The air ejector is the first to go.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
