Cast Iron chambers needed
old_dog
old_dog Member Posts: 2
Does anyone know where I could find American Standard Cast iron chambers
(need 3)
boiler number PFA-313  Series 1B-J1
This is a 40 year old unit.
Thanks
Claude
    Steamhead Member Posts: 18,187
    Sure about that model number?
    This would have been an A-3 series set up for pressure-firing, but the way the model numbers worked on this series, you're describing a 13-section boiler. Do you know how many sections it has?
    Consulting
  • old_dog
    edited July 2014
    # of chambers
    I think there are now 7, but some were removed.
    Don't know what it had originally.
    3 are now shot.  Trying to milk a couple
    more years out of it as we insulate and
    change windows to this converted school.
    Then will put in a new unit at around 1/2 the
    capacity.
    I will try to get a couple pics posted Monday,
    and verify the Model/Series number.
    Thanks for the help.
    Claude
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,578
    Old boiler repair
    It would be best to bite the bullet, and replace it with a new wet base boiler, and a burner which can be fired within the ranges of the present radiation, and any future additions you may make.
    Is this a 1-pipe, or 2-pipe system?
    When you dismantle a 40-year old boiler, there can be unpleasant surprises. Finding new press nipples to rejoin the new sections (if even they can be found), could be difficult.
    A 7 section boiler is in the range of 1,000,000 to 1,300,000 btu, and could be replaced by a pair of smaller pre-assembled boilers, staged by pressure.--NBC
