Just wondering about oil tanks
DanHolohan
Member, Moderator, Administrator Posts: 16,643
Does anyone know why they chose 275 gallons as the size for most houses?
Retired and loving it.
oil tank size
Here's one or two thoughts .Width they always seem to just squeeze through a 28 inch basement door,The other thought is the volume most smaller homes w a 275 usually had a tankless coil and I fiqure that in the off season when just being used for hot water they could maybe get by for about 1 to 1 1/2 months with a delivery.Alot of the oil jobs I used to service had 275 tanks and went at least that long off season but usually got a oil delivery at least once a month but a lot of times it would just be a top off.Peace and good luck clammyR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
I think Clammy's right
the oblong shape appears to have been chosen so you could get it thru basement doors, and the length and height so you could get it around corners. The resulting capacity worked out to 275 gallons or, if you could get away with a longer tank (72 rather than 60 inches) 330.All Steamed Up, Inc.
Consulting0 -
275 and 330
are both divisible by 55. Think barrels. Note these are also the standard sizes of IBCs.0 -
What
About Roth oil tanks now that we're on the subject, who here took the Roth training course ( about 2 hours)0 -
Golden section
The golden section / ratio is 1.618 to 1 or rounded 1.62 . The proportions of the end view of the 275 gal oil tank are 44/27 or 1.62 to one. The proportions of the Parthenon are the same. Coincidence ? Great minds .There was an error rendering this rich post.
Diagonal Measurements.
You always have to take the diagonal measurement into consideration.0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 991 Plumbing
- 389 Solar
