Advice needed on heating system install
FredCapo
FredCapo Member Posts: 21
Hello. I recently purchased a house that I am in the precess of renovating. I am retired and have some experience having helped install several hot water baseboard systems with a licensed contractor. The house I purchased has an oil fired burnham pv84sl with single pipe steam system. I want to put in a nat gas hwbb system. I will try to find someone to take/purchase the vintage radiators. My question is...is it worthwhile to try to convert the burner to natural gas and re pipe for hwbb or just buy a new gas boiler? Thanks for any advice.
    Steamhead Member Posts: 18,062
    You'd spend a lot less money
    by fixing the steam. What exactly is wrong with it now, besides being oil-fired?
    Consulting
  • FredCapo
    Oil boiler conversion
    Thanks for responding, but we don't want oil or steam. I am just trying to determine if the boiler is a good candidate for conversion. Additionally I have seen some misc comments on Internet saying that the burnham v series is problematic with boiler failures of the casting. This is a 2005 model. Thanks.
  • Snowmelt
    Snowmelt Member Posts: 1,448
    Where are
    You from, i maybe able to take the rads.
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,577
    no steam-no oil
    why is it you are rejecting steam? when steam systems were being regularly installed, they were sometimes regarded as superior to gravity hot water, because of their efficiency. those old systems were quiet, even, and economical.--NBC
  • gennady
    gennady Member Posts: 840
    Steam to hot water.
    I get these requests all the time. What is about this obsession with steam to hot water system conversion. To do it right costs a lot of money. And still most of conversions done completely wrong and with poor craftsmanship. Instead of fixing steam system, what most of the time consists of installing proper venting,fixing pipe supports and near boiler piping, people run this pex all over, install unbalanced radiators or baseboards and oversized boilers.
  • Gordy
    Gordy Member Posts: 9,546
    Steam
    Is actually quite elegant, and others have mentioned ..........
  • FredCapo
    It is an old well built house
    But the second floor steam pipes are outside the wall, the addition is presently heated with electric baseboard, and we have nat gas service. I installed hwbb in my present home with a little outside help and it is fine trouble free. I'm glad you guys like steam heat. I like vintage guitars and vacuum tube amplifiers but I am going forward with nat gas hwbb...burnham or not.thanks.
  • chapchap70
    chapchap70 Member Posts: 139
    New boiler and new piping
    If you are dead set against steam, change out the Burnham for a low mass hwbb system with maybe a wall hung boiler.  Radiant might be the way to go if you are going to rip it all out.
