GEO COOLING
COAL
COAL Member Posts: 2
THINKING OF DOING GEO COOLING. IN A COMMERCIAL BUILDING WITH EARTH LOOP. HOW DO I GO ABOUT THAT? DO I NEED HEAT PUMPS? IF I DO WHAT FOR?
  • Snowmelt
    Snowmelt Member Posts: 1,457
    First
    Thing is find a contractor , the heat pump is the heart of the system for cooling where the Geo thermal is the lungs and arteries.
    Gets a little more complicated then that.
    As a rule of thumb for every ton of cooling you have to dig a well 100 feet, or have 200 feet of piping 100 ft each way.
    Lots of times this requires some engineering skills.
    Where are you located?
  • COAL
    cold country
    located in northern montana
  • Rich_49
    Rich_49 Member Posts: 2,785
    Thermal Battery Systems
    Contact James Schenck . He is who you wanna speak to . Listen to what he has to tell you and be glad you did .
    https://www.linkedin.com/groups?home=&gid=4967184&trk=my_groups-tile-grp
    732-751-1560
    Rich McGrath 732-581-3833
  • icesailor
    icesailor Member Posts: 7,260
    Montana Water:
    If you are considering Geo-Thermal in Montana, be sure you consider the quality of the ground water, Some areas of Montana have some serious ground water quality issues that can severely effect the heat transfer abilities of the HX'ers.
