What is the name of this oil tank filling fitting?
Sparky49
Member Posts: 18
in Oil Heating
This is on the wall of a house in Reading PA. The house was built in 1900, and used to have a steam heat system.
Sorry about the odd angle of the photograph.
It's called "an accident waiting to happen"
assuming the tank is no longer there- every winter SOMEONE gets a basement full of oil because someone hooked up to the tank at the wrong address. That needs to come out NOW.
Same with the tank, if it's still there but no longer used.
And you say the house "used to" have a steam heat system?All Steamed Up, Inc.
Consulting0 -
ditto Frank
If it is no longer an oil fired unit in there, have that fill, vent, and possibly the tank removed. The ones running around doing conversions, and not following thru with the legal removal of the old tanks and piping should be held accountable, and hung, not the poor person that made an honest mistake, and filled the tank/basement0 -
The oil tank is still there they are still using oil to heat, just not steam.
I'm just trying to identify the make and model of the connector for the delivery hose.0 -
FILL
It's a "KLEEN FILL" made by Time Saving Fills in York PA.0 -
Thanks
Thank you Buster.0 -
Good comments
Frank and Bill,
Your comments are on the spot. I have heard too many stories about the oil being "delivered" to the wrong address through a disconnected pipe. The typical oil truck driver makes 20 to 50 or more deliveries a day and could easily deliver to the wrong house.
Worse, some accounts are on an automatic delivery schedule and if the homeowner does not tell the oil company that the tank was removed...
I see about ten tanks that fail a year due to problems with the venting too. All sad stories. I wish I could tell them someday.
nuff said.0 -
I still see that fitting once in a while.
It is old and I remove it when I come across it because an adapter is needed to hook up the hose from the truck to the fill. That fitting is prone to leaks when filling the tank.
If you are still watching this thread, a better solution would be to replace that with a "scully" fitting. A direct replacement would be a male 45 scully. You could get it from a plumbing supply. Some oil companies carry these fittings on the truck and replace these.
One issue that I foresee is that a person might be afraid to remove that fitting from the outside because the pipe inside might move before the fitting. This may be a two man two pipe wrench job.0
- 120 Geothermal
