GEO COOLING
COAL
Member Posts: 2
THINKING OF DOING GEO COOLING. IN A COMMERCIAL BUILDING WITH EARTH LOOP. HOW DO I GO ABOUT THAT? DO I NEED HEAT PUMPS? IF I DO WHAT FOR?
First
Thing is find a contractor , the heat pump is the heart of the system for cooling where the Geo thermal is the lungs and arteries.
Gets a little more complicated then that.
As a rule of thumb for every ton of cooling you have to dig a well 100 feet, or have 200 feet of piping 100 ft each way.
Lots of times this requires some engineering skills.
Where are you located?0 -
cold country
located in northern montana0 -
Thermal Battery Systems
Contact James Schenck . He is who you wanna speak to . Listen to what he has to tell you and be glad you did .
https://www.linkedin.com/groups?home=&gid=4967184&trk=my_groups-tile-grpYou didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
Montana Water:
If you are considering Geo-Thermal in Montana, be sure you consider the quality of the ground water, Some areas of Montana have some serious ground water quality issues that can severely effect the heat transfer abilities of the HX'ers.0
- 109 Chimneys & Flues
- 972 Plumbing
- 386 Solar
- 17 Recall Announcements
