Can this boiler leak be fixed? (homeowner w/ pictures)
KurtOP
Member Posts: 2
Hi-
My Weil McLain (model E-5, probably 50 years old) boiler has a slow leak of water coming from the area around the black panel.
Is this something that can be fixed?
What would your advice be to the homeowner?
Thanks,
Kurt
Thanks,
Kurt
IS this a ....
Steam or hot water system? If its a steam you MAY be able to buy some time w/ some boiler seal. If it hot water forget it. To be really frank though is July, it warm out and it really needs to be swapped out for another boiler. There are a lot of good options out there.
Where is your location?
kcopp0 -
Fix:
If YOU are really handy with tools, and you are a motor head from youth and don't mind attempting impossible projects, if you believe that it can't be repaired, you can probably fix it. It can be a really easy fix for someone experienced and was willing to futz around. And that is the only place it is leaking.
That didn't start last week. That's like someone with symptoms of Prostate Cancer and hoping it will go away on its own. 5 years ago, it might have just required a new gasket and some care. Today, someone could spend a lot of useless hours on a futile project. If it were mine and MY back was against a wall, I would try to fix it with the intent of replacing it. If you need to hire someone to try to fix it, replace the boiler.
Unless you know someone who can fix ANYTHING and sometimes, a broken heart, it can be futile.0 -
best to first
just have a pro look at it. Looks like a leaking section from the pic. Most of the damage is above it, and looks to be a small hole there. Might be more than just a coil plate gasket leaking there. Good luck0 -
Why
Would you want to fix it? ITS 50YRS OLD!!!! It's done, lived a good life and served its purpose. Time for a new boiler.There was an error rendering this rich post.
More Info
I appreciate your helpful comments. I am handy, but more likely to tackle the low-hanging fruit. I think this is beyond my skill-set.
Assuming the boiler needs to be replaced...
Question #1: This is a "gravity feed" hot water system. Will a new boiler work with "gravity feed", or would it have to be converted to a system with a water pump?
Question #2: My heating system seems to have two "loops". There are two hot water lines leaving the top of the boiler and two return lines. Will a new boiler support that system?
Question #3: What is this going to cost?
Question #4: How do I find a good contractor? What should I look for? What are red flags? I'm in the Chicago area (Oak Park, Illinois).0 -
Repair or replace
Replacement is the lowest hanging fruit you will find in this. The new boiler, whether it be cast iron, or mod con must be chosen for its ability to keep up with the heat loss of the building, so use the SlantFin software to calculate that.
Use the find a contractor button here to find an expert in your state, and compare his heat loss calculation with your own. Check his references for such installations.
Do a search here for gravity systems, and read the various post on the adaption of new boilers to old systems. Many manufacturers will provide recommended piping diagrams for gravity system installation.
We do not discuss pricing here as the costs vary state by state.--NBC0 -
Fix
Not too long ago I replaced a coil in a boiler just like yours. I advised the customer to replace boiler but they had no money so after a long delay we replaced the coil.
Well, it lasted for about 3 months and the boiler began leaking because it had been neglected for too long (like yours) and the cast iron had rusted through. I got a phone call at 8 pm one night and there was a foot of water in the basement. It cost them about $10-12K for Service Master , damaged property,(furniture from another home was being stored) and a new boiler. Well, at least the basement got cleaned!
My advise, replace the 50 yr old boiler.
http://www.heatinghelp.com/find-a-contractor
http://www.heatinghelp.com/article/332/Gravity-Hot-Water-Heating/72/Gravity-Hot-Water-Heating-FAQ0
- 50 Industry Classes
