Gas-powered pump releases CO into house in Beverly, MA
DanHolohan
DanHolohan Member, Moderator, Administrator Posts: 16,713
Beverly, Mass. —
The Beverly Fire Department responded to 13 storm-related calls
today as of 5:30 p.m., including one in which a house had high carbon
monoxide readings caused by use of a gasoline powered pump.
Deputy Fire Chief Peter O’Connor said many of the calls the
department received were from residents who had water-filled basements.
However, some were caused by water going through smoke detectors.
The most serious incident occurred at 5 Thoreau Circle, where the use
of a gasoline powered pump to remove water from the basement resulted
in high carbon monoxide readings in the home. The house did have a
carbon monoxide detector, which provided a warning to the occupants.<a href="http://www.wickedlocal.com/beverly/news/x1526466018/Gas-powered-pump-releases-CO-into-house-in-Beverly">http://www.wickedlocal.com/beverly/news/x1526466018/Gas-powered-pump-releases-CO-into-house-in-Beverly</a>
Retired and loving it.
  • RobG
    RobG Member Posts: 1,843
    Why?
    Why did a 2010 posting get recycled?
